Thanks for trying the new image. It’s still in beta, but for me it’s been working fine so far.
Yes it runs the full desktop. A few customers requested the desktop on the Pi 4, but I didn’t want to activate that because then customers might run other programs like the web browser and end up congesting the CPU so much that Kraken samples are lost and hence coherence is lost too. Then people end up wondering why the Kraken doesn’t work well.
But on the Pi 5 we have enough processing power that that shouldn’t be an issue.
I did notice restart and shutdown issues too, but that’s all to do with the Raspbian OS image, and not the Kraken.
Versus the Pi 4 you shouldn’t notice any difference in DoA performance. The Pi 4 already runs the DoA code at full speed. The main advantage is going to be a more snappy UI and faster boot.
I’ve been having an issue connecting to my local network with the Pi5. I followed the standard wpa_supplicant instructions on the Pi4 and it linked right up, but for some reason the Pi5 is refusing to do it. I put my network credentials into the config, and typically it will encrypt the password and save it back to disk, but it doesn’t anymore. This is on a fresh image that I flashed last night. Running over the default hotspot, I can access the machine through SSH and the kraken software runs perfectly fine.
I am just out of the box here. PI5 with downoaded image, talking to android phone, at least I wish it was.
I have the hotspot set up with “krakensdr” as username and password.
First question: 2.4 ghz or 5? Does it matter?..
I see one white light on the sdr for power, no noise light. The sdr is connected to one of the four usb a ports on the pi. Both the pi and the sdr are running from the same power bank which is at 96%
I never see the pi connecting to my hotspot, and the android app tells me nothing
If you connect a monitor to your Pi5 you will load to a desktop (assume your using the supplied image), in the upper right hand corner will be all your wifi settings. You can configure your wifi from there. I have not been successful in any other way to get the Pi5 to connect to wifi.
I was really hoping to avoid that. I’m sure I could disable that network manager, but it would be so much better to drop in one file and it just work, like it did before. Oh well.
wpa_supplicant is no longer used on Bookworm, which the latest Raspbian used for the Pi5 image is based on. You’ll need to configure it through the UI now.
I have just (yesterday) downloaded the RPi5 image. It has been a few months since the Kraken was set-up in the car and am blaming the long wet winter in the UK for this. But have been very impressed with the performance of the software on the 5. Everything just seems to work first time. Apply power to the Kraken, then the Pi and finally connect using the Android phone. I have repeated this exercise several times and it has been faultless. Over the weekend, I hope to demo the set-up to a public facing Ham radio event in Suffolk, UK. I am putting together a slide pack explaining radio direction finding. Has anybody done the same? The Rohde & Schwarz YouTube video, [Intro to DF] has been useful with putting this together. Tom. G0JSV.
Is there a way to get to the UI without attaching a monitor. I usually go through SSH.
I haven’t tried it yet, but VNC and remote desktop might work assuming that the image we are using will support everything needed.
I have found that raspi-config does not work for setting up the wifi. It does work for other things like changing the password on the unit, but errors on wifi settings.
Is this on the Pi 5? Only the Pi 5 image has the desktop GUI enabled. But I note that there is no Kraken UI on the desktop, I am only referring to the OS desktop.
If you want to get into the Pi 5 desktop, you could try enabling VNC and connecting via the Raspberry Pi’s RealVNC solution.
Yes the OS desktop. Got connected using xrdp on pi and remote desktop on pc. Only issue is permission issue when trying to adjust the wifi. Says network scan not allowed. Working on the permissions.
Everything on the Pi 5 image apart from the KrakenSDR software install is stock Raspbian including permissions. The only changes made are via the network settings GUI to enable the hotspot KrakenAndroid connections and set their priority.
