Hello everyone, I have the following problem. Can I work with a device that transmits a signal width of 10 MHz, 20 MHz or 40 MHz?
Will Kraken be able to correctly display parts of this signal in the 2.5 MHz range?
You won’t be able to see the full bandwidth, but you only need a small sliver of bandwidth to be able to use the DFing algorithms on it.
