I see that its possible to change the ADC sample rate. I haven’t found any documentation on what ranges I can change this to. IS there any resources someone could point me to about the ranges of AD sample rates with the Kraken SDR?
2.4 MSPS is the maximum with KrakenSDR.
With general RTL-SDRs the maximum is typically 2.56 MSPS, but because the KrakenSDR uses the hardware resampler to align the USB samples for coherence we’re restricted to slightly lower than 2.56 MSPS, since adjusting the PPM could cause the sample rate to go above the maximum stable rate and cause drops.
