WebSocket messages
What message is used to set frequency from the front-end settings page over websocket? It should set frequency much faster than by updating a JSON settings file. There are too many messages flying to find one by myself and it would take ages for me to dig through the code. Could you elaborate please?
P.S. Is there another way to set frequency or other settings except for websocket and editing the settings file?
Hi, do you want to emulate the webui under (krakenip:8080) or what exactly is your goal?
I had a look at the websocket in the webui, the python framework used for the UI makes quite complicated calls (as you already mentioned) so i would not use that for some external script, also because it could change in future software versions.
The main way to set new settings is editing the settings json file (if not using the webui on the kraken), you can do this by hand or use some kind of script. If you change settings in the cloud mapper (map.krakenrf.com) we internally also edit the settings file to update the settings.
regards,
Manuel
