I have been struggeling with getting the krakensdr working with gnuradio.
I am using the virtualbox image, but I am unsure how to start the heimdall server so it can be used.
Any hint would be appreciated.
Kind regards
Jesper
Kind regards
Jesper
I will just provide a bit more context.
I have changed the config file (heimdall_daq_fw/config_files/kraken_default/daq_chain_config.ini) to use eth
and I am using the heimdall_only_start.sh from the gr-krakensdr repo to start.
The program starts up and I can see that the machine is listening on port 5001.
But I am unable to connect. It seems the port 5000 is not open.
Having restarted my attempt I succeeded getting a bit further. I started from the virtualbox image, and discovered that I had edited the wrong config file.
After having changed this I am now able to start the server so both port 5000 and 5001 is listening.
I can also cennect with the FFT sample for GnuRadio. But the graphs show no activity. I will keep digging.
I’m on a different PC at the moment so I can’t look it up exact, but in the image there is a folder gr-heimdall, or something like that. You can run heimdall from that folder, and then open gnuradio-companion and then open a KrakenSDR example flowgraph. Then it should connect when you start.
I can start the “flowchart kraken_fft_display” and I get the gui and all.
There is no movement in the plots and the log repeats this error.
Exception: index 2 is out of bounds for axis 0 with size 2
Failed to write output_items
Failed to put IQ Samples into the Queue
Exception:
Exception:
and it just repeats itself from here.
Any hint is appreciated.
I feel silly. I got it working, after restarting my attempts.
Here is waht I did:
I did a fresh unpack of te virtualbox image:
I had to choose a differen network adaptor to start the virtual machine
And I added 128MB of display memory
Opened a terminal and checked I had 5 rtlsdr devces with
lsusb
I went to
~/gr_heimdall_daq
And ran ./heimdall_only_start.sh
password: krakensdr
Start gnuradio.
Open kraken_fft_display.grc
Press run.
It took two attempts to get it running, but I saw live data.
