Newbie here ![]()
I want to be able to use my kraken to feed multiple pc based programs / decoders. Eg ADSB / AIS / NOAA Satellites etc.
How do I go about doing this?
Do I need a sdr driver for each of the 5channels?
Do the individual channels show up as a pre- numbered sdr ?
Any other suggestions / help will be very much appreciated.
R
KrakenSDR will show up as five RTL-SDR devices.
So if you’re not using any of the coherent features, you can just treat the KrakenSDR as 5 independent RTL-SDR’s.
Only one driver install is required. There will be a unique serial number for each of the RTL-SDRs that show up.
Thank you for the help.
All set up and working as desired. I am using SDR++ in which they do indeed show up as individually numbered RTL units (numbered 0 to 4).
I loaded up 5 separate instances of SDR++ and all can run at the same time. Just what I wanted.
I’m interested in using the KrakenSDR as a multiple receiver array in a single piece of software that could be configured to drive all 5 receivers to sweep several bands simultaneously. Instantaneous bandwidth is the bottleneck, I know. Does anyone know if there’s an existing software that can be configured to do this without too much drama?
Thanks!
Just for sweeping and logging data, or also for recording wav or IQ files?
Something like rtl-airband or rtl-sdr-scanner-cpp could be used to monitor multiple channels over a wide swept bandwidth.
If you’re just wanting to measure the spectrum power, then rtl_power should be able to handle that.
@Rogerken1 I recently set up a Kraken to do similar things.
There’s some unorthodox steps and a few undocumented steps.
I wrote up my efforts here: GitHub - alorman/KrakenSDR-Notes: Notes on Using the Kraken SDR for ADS-B/AIS/LiveATC
