Which USB should I plug the kraken data port in? I heard the USB3 can cause bad interference with some devices so I would go USB2, but I dont want to run into bandwith issues, whats the recommended USB port to use as DATA port?
The KrakenSDR is a USB2.0 device, so either port will work the same. I haven’t heard of the USB3.0 ports being more noisy, where did you read about that?
