Ubuntu + GNURadio Install
Hi, new user here. Just trying to figure out how to setup to simply stream in GNURadio from Kraken SDR with Ubuntu.
  1. Ran the x86 64 bit install scripts:
wget https://raw.githubusercontent.com/krakenrf/krakensdr_docs/main/install_scripts/krakensdr_x86_install_doa.sh
sudo chmod +x krakensdr_x86_install_doa.sh
./krakensdr_x86_install_doa.sh
  1. Installed gr-krakensdr
sudo apt-get install gnuradio-dev cmake libspdlog-dev clang-format
git clone https://github.com/krakenrf/gr-krakensdr
cd gr-krakensdr
mkdir build
cd build
cmake ..
make
sudo make install
  1. Followed gr-krakensdr instructions:
    In the heimdall_daq_fw folder edit your Firmware/daq_chain_config.ini file and change out_data_iface_type to eth.
[data_interface]
out_data_iface_type = eth
What am I missing? Running ./kraken_doa_start.sh gives me a constant stream of “WARN:Ports used by the DAQ chain are not free! (5000 & 5001)” i.e.
Shut down DAQ chain ..
However running lsof -i :5000 and lsof -i :5001 says those ports are not being used.
Running the super simple GNURadio block to test and nothing pops up
Screenshot from 2023-12-11 01-21-58
Any suggestions what I’m missing or what I should try? Thanks
If you’re connecting to GNU Radio, make sure you are following the right instructions. GitHub - krakenrf/gr-krakensdr
Make sure you are running ./heimdall_only_start.sh, not ./kraken_doa_start.sh as the latter will also start the Python DOA code which you do not want running.
working with Krakensdr using gnu radio is important and need to be more explained for beginners (like my self). im also facing problems
What problems are you having?
im trying to use krakensdr on an x86 device via ubuntu. I tried my best following the instructions (im a beginner in these fields) but when I execute any example flow graph on gnu radio I get the following error and gnu radio crashes.
ErrorMsg
I fixed it. The main issue was that the krakensdr root directory is krakensdr_doa not krakensdr
Thank you, yes that was certainly a problem. However still running ./heimdall_only_start.sh still gives me the same error:
~/krakensdr_doa$ ./heimdall_only_start.sh
Shut down DAQ chain …
[sudo] password for kraken:
Did you run kraken_doa_start at some point before? It seems like the Kraken software stack is still running from a prior run which is why the ports are in use.
You’ll need to shut it down first with kraken_doa_stop, or just restart your PC (assuming you haven’t done anything to make the software autostart).
Yeah I thought it might be that but I tried restarting the PC and still got the error after runnning just heimdall_only_start.sh
Then there must be some other software using the same ports running on your PC. Can you try:
netstat -ano | grep 5001
netstat -ano | grep 5000
This should show you what program is using these ports.
Hi!
I’m trying to set up the Kraken SDR with Ubuntu + GNURadio but I’m struggling with using heimdall_daq_fw.
When I set “out_data_iface_type = eth” in the daq_chain_config.ini and run “sudo ./daq_start_sm.sh”, I see error in the “delay_sync.log”. An because the delay_sync.py is crashing the iq_server is in a blocked state.
Traceback (most recent call last): File “/home/zp/code/krakensdr/heimdall_daq_fw/Firmware/_daq_core/delay_sync.py”, line 41, in import skrf as rf ModuleNotFoundError: No module named ‘skrf’
How are you using it? I don’t see how it could work when the python modules are installed in the conda environment but the script is running as sudo.
Update 1: Just for the completeness, when I’m running “./daq_start_sm.sh” without sudo I’m getting the following error:
chrt: failed to set pid 0’s policy: Operation not permitted
Update 2: The build looks good in that sense the unit test passes after reverting c525212da63c316169e9b1ef47d6791bba1af202 . (That change removes shared memory unlinking which seems to brake the unit test.)
Your install is missing the scikit-rf package.
conda activate kraken
conda install -y scikit-rf
Thanks — but in my case scikit-rf is already installed in the conda environment, so that alone doesn’t resolve the issue.
The underlying problem seems to be that daq_start_sm.sh (and therefore delay_sync.py) must be run with sudo, which causes it to bypass the current user’s conda environment. As a result, even though scikit-rf is available in conda, it is not visible when the script runs under sudo, since root uses a different Python environment.
So the issue is not simply a missing dependency, but a mismatch between:
  • Python dependencies installed in a conda environment
  • Execution happening under sudo, which does not preserve that environment
This is also why I was asking how daq_start_sm.sh is intended to be run on Ubuntu in your setup. From one side, chrt requires elevated privileges, but on the other side the Python layer expects packages from a user-level conda environment, which becomes inaccessible once the script is executed under sudo.
So this is the proper way to start daq:
sudo env “PATH=$PATH” ./daq_start_sm.sh
