Congratulations. tell me if it is necessary to use a linear array when stationary installing several krakens. For the correct display of bearings in the heding section, do I have to specify the direction where the 0 dipole is directed or something else?
It is not necessary, you can and we do recommend using a circular array even in a fixed site setup.
If you want to use a linear array, yes you would be best to specify the direction if you know that you will only be monitoring in one direction.
i use linear array for more precision. the question is what to specify in the hading section
You can define an orthogonal direction as forward, and whatever heading the orthogonal is pointing to is your forward heading.
