First, I can connect to krakensdr and it working well but after I reboot system I got like this however I reinstall again and I can enter into kraken site but just a few moment it became “Unable to connect” and I already check power cable it working well. Even I ran the block in gnuradio there isn’t anything respond on graph(it was working well)
In case that I can enter into site I never connect to kraken again when I reboot system like it able to connect once time
**PS my cable working well because it was connect at first time and I was used it till I reboot. I saw this problem several but nobody not able to fix it and they try to said about cable but isn’t it.
Hi, how are you rebooting the system? Hard power off, or via the reboot buttons in the GUI?
I did a “sudo reboot” on jetson orinNx
If you do a hard reboot by power cycling does the same issue occur?
I have seen issues in the past, not only with KrakenSDR, but with ARM Linux in general. Sometimes sudo reboot will fail, and the system will get stuck.
Also try “sudo reboot -f” to see if the force flag helps.
Yes, it is whatever I did “sudo shutdown now” or turn off switch or plug out Jetson orinNX. And when I try to connect to krakensdr again it does not connect again
