Static Station Settings: Heading
I have read the documents and just want to clarify.
" Latitude/Longitude/Heading
If you have selected your location source as ‘Static’, you can enter the latitude, longitude and antenna array heading for your stationary KrakenSDR station."
That heading would be based on the top down view of the UCA antenna 0 being the orientation of the array and the compass heading that one would enter into the static settings?
This is how I interpret it.
Thank you
Happy Hunting
Correct, in the static case the heading is the compass direction that element 0 faces.
very good.
Next question. I understand that logging gets paused when travel speed is under “X” Kph.
I seem to be missing how to set the config to a “static” config. I have a use case for a static config and a mobile config.
Where in the documentation am I missing good static configs?
If you’re using the app, just set the logging mode to “Log Everything”.
If you’re using the web mapper, then it doesn’t pause so there is nothing to change.
