We have been using krakensdr for a while, and one thing we cant find or understand how to use…
Example.
Lets say its a carrier that transmit for a while, then quite for a while. Then back again, instead of stop DF manually, can we put squelsh threshold high ,and Kraken SDR stops, and continue collect data when signal is back.
Is that possible?
Yes exactly, in the web interface either set Auto squelch, or determine a manual squelch level from viewing the spectrum.
Then when the signal transmits, you will get DOA data. When it doesn’t transmit, there will be no DOA data, and the mobile mapper won’t update.
