Signal homing drone
Has anyone tried to design a signal-homing robot or drone based on the DoA determination by the Kraken SDR? The target could be the long-range communication of the FPV drone or GNSS jammer/spoofer. Both signals are at a frequency of Kraken.
I know that people have talked about this, but I have not personally seen it.
Hi could you elaborate on this a little. It seems quite a good idea nd surprised no one has done it?
Hi, the solution for a 2D signal homing looks pretty obvious, since we have a lobe on the diagram, the task is reduced to following that direction. The more interesting case is to try to build a 3D diagram - aziuth AND elevation.
