Setting Minimum Power lever (dBm) for spectrum and DF
I wanted to know where in the code I could set a minimum power level for the system? I want the system to bassicly ignore all data that is below a certain dbm.
The reason for this: In our use case the kraken and RPI are physcially close together so there is some leakage from the rpi to the rf cables.
Thanks so much,
You can use the squelch feature in the KrakenSDR web GUI which works on SNR. Set it so that the squelch only activates when the signal level is above an appropriate threshold.
