Set Block Sample Time
KrakenSDR is running on Pi5 with October 24-005 release. I would like to take bearing from a master with seven clients sending on the same frequency in burst mode. Eight stations with different angle of arrival (AOA). The KrakenSDR samples by default in 436 ms blocks. Therefore, I must reduce block time from 436 ms down to 50-80 ms. Maybe the write time into the log must be more often executed than once a second. Yes, it’s clear the logfile will extend very fast, but I would like to trace a master with seven clients sending/bursting on the same frequency with different AOA. Where can I set in GUI block sample time and write period? Please send advice.
Detailed release information: Pi5 Oct24-005 Version 1.8.1+git.e5df8c9 release.
If you enable the Basic DAQ settings you can change the data block length. You’ll need to be running something relatively fast like a Pi 5 to be able to use a faster time and maintain stability.
