Is it possible to change frequency and other settings in krakensdr via external control? Im thinking about make my own software to control my wide band receiver, and in same time change settings i krakensdr. Is there information about external control?
The problem with changing frequencies is that the array size also changes. There are frequency ranges that be used with a single size of antenna array, but the precision of the lowest frequency in the range will be much lower than the highest frequency.
What frequency range do you want to cover?
Hi, i will only use it on VHF for the moment. But very interested on how to change FQ and other settings from " outside" so to speak, is it possible at all to do?
What is the frequency range that you would like to cover?
I’d like to do something similar, but only switch frequencies within my current antenna array. If I’m running SDRTrunk or Unitrunker, what’s the best way to remotely retune the Kraken RF’s frequency while I’m locked onto a talkgroup?
You can simply create software that edits the config file. When the config file is edited the Kraken software will automatically detect the changes and make the changes.
Good, just what i suspected. I have done software for it. Thanks
