RaspPI reboots periodically when plugged into Kraken
My Raspberry Pi 5 periodically reboots when plugged into the data port on the Kraken. Doesnt advertise Krakensdr ssid. If I unplug the Kraken from the Pi. Pi stabilizes and advertises Krakensdr ssid. I can connect, but :8080 will not connect. Error is connection refused.
I was able to stabilize the Kraken by using a separate USB power block from the RaspPi. I had originally used a multi-outlet power block and I’m guessing there wasnt enough isolation between the ports.
The krakensdr SSID is stable and connectible but the browser now reports address unreachable. Im using http://192.168.50.177:8080.
How can I connect?
Thanks,
Gil
Are you connecting via your phones mobile hotspot? How did you find that IP address?
You can find the correct IP address in your phone’s mobile hotspot settings page.
