Radio Signal Coverage Mapping
Is there any avenue to use the Kraken as a sort of drive and plot signal strength mapping system that would ultimately provide a coverage map? The is a system called RTLSDR-Scanner that works ok on a windows PC but isn’t really supported any longer.
Thanks,
Devan
The KrakenSDR app already does this somewhat similarly to RTLSDR-Scanner.
Each point logged contains power information, and the point is colored according to its received power relative to other log points. (When you enable plot log file)
But we don’t expand that out into a wider heatmap. I guess we could look at ways of creating a wider heatmap from the power values too.
That was actually the drive behind the question. It seems like it is so close already. I was hoping that it was capable and I just hadn’t read about yet. Its main usefulness for me would be when my agency lights up a new site (over 360 now), I could go out and just drive the area and get an actual coverage map rather than just a coverage study from TAP.
Thanks for the response, much appreciated. Where does one submit an actual feature request?
hahaha…
Best place is here on the forums. I’ll add it to the list here Android app requests from forums · Issue #140 · krakenrf/krakensdr_doa · GitHub
