Question on antenna array radius
I set up my antenna radius for 467.700, but now i need to be able to quickly jump between 467.700 and 444.400 …
How much of a difference will there be when i’m on 444.400 with the radius set for 467.700, and what will be the result?
You can safely change between those two frequencies. What resolution does the selected array radius provide at 467 MHz and 444 MHz? Did you choose your radius with the array calculator spreadsheet?
Depending on what you set your radius at, according to the spreadsheet, the resolution will change by less than a degree. Still doable.
