Phase alignment when logging 5-channel IQ streams with File Sink in GNU Radio
Hello KrakenRF community,
I’m working on logging IQ data from all 5 output channels of my KrakenRF-based receiver, using GNU Radio Companion’s File Sink blocks. Everything streams correctly, but when I inspect the recorded files later (e.g. loading them into Python/Matlab and plotting the instantaneous phase of a test tone or noise source), I see a constant phase offset between channels—even though I’ve synced their start timestamps.
Can you please clarify, are you using heimdall_daq anywhere in your receiver chain? Remember that the Kraken isn’t coherent without taking data from heimdall. If you’re just opening 5 seperate streams directly in GNU Radio it won’t work.
