Per-tuner error (ppm)
I use my KrakenSDR with SDRTrunk that allows for ppm correction for each tuner. Since the SDRs in the Kraken are coherent, does that mean the error for every tuner should be exactly the same? So if one is off by .2ppm, all the others are off by the same amount? Assuming theres no oddball temperature issues…
Yes there is only one TCXO, so the PPM error of that single TCXO will be global to all the tuner units on the KrakenSDR.
