Passive SDR Radar with KrakenSDR: DVB-T2 for Drone/Target Detection
Hello everyone,
I’m starting a new open-source project aimed at developing a fully functional Passive SDR Radar (PCL) system using the KrakenSDR platform. The primary goal is to effectively detect and track dynamic aerial targets (like drones and aircraft) by processing existing broadcast signals, specifically DVB-T2, in the 514 MHz range.
We are currently in the architecture and initial development phase, and I welcome any feedback, expertise, and collaboration from the KrakenSDR community, especially regarding signal processing and phase calibration.
Project Overview & Goals
This system operates entirely passively, making it robust against electronic countermeasures (ECM).
  • Hardware: KrakenSDR (5 channels), 5 x Yagi-Uda Antennas (1 Reference + 4 Surveillance for a phased array setup), Raspberry Pi 5.
  • Illuminator: DVB-T2 broadcast signals (around 514 MHz).
  • Target: Drones, aircraft, and missiles.
Core Processing Pipeline
The project focuses heavily on signal processing to separate moving targets from static ground reflections (clutter). Our pipeline involves these key steps:
  1. IQ Data Acquisition: Capture raw data from the 5 KrakenSDR channels.
  2. Calibration: Synchronization and phase calibration (a critical challenge with non-coherent sources).
  3. CAF Calculation: Generate the Cross Ambiguity Function (CAF), which creates a delay × doppler map (our radar frame).
  4. Clutter Suppression: Apply MTI (Moving Target Indication) or FIR High-Pass filters along the time axis to suppress stationary echoes (zero-Doppler).
  5. Detection: Use 2D CFAR (Constant False Alarm Rate) to extract targets from the filtered CAF maps.
  6. Tracking: Implement a Kalman Filter combined with the Hungarian Algorithm for robust data association and continuous tracking of targets (creating unique IDs and time series data).
Current Focus & Challenges
We are seeking advice and discussion on the following technical points:
  1. Phase Synchronization: Best practices for achieving precise phase synchronization between the four surveillance channels on the KrakenSDR using an external clock or through software compensation, especially for non-coherent DVB-T2 signals.
  2. CAF Optimization: Techniques to optimize the computation time of the CAF on resource-limited devices like the Raspberry Pi 5.
  3. MTI/Clutter Filtering: Experience with adaptive clutter suppression algorithms (beyond simple MTI) for PCL systems utilizing OFDM signals like DVB-T2.
Repository and Collaboration
The project structure is available on GitHub. We are organizing the code into logical folders (src/, config/, systemd/) and are documenting the technical specifications in the docs/ folder.
GitHub Repository: https://github.com/Stanislav-sipiko/passive-sdr-radar
Feel free to check out the repo, submit issues, or share your knowledge here!
Thanks in advance for your input!
You have 6-months invested in your project at this time, so do you have a working prototype for your code yet that can be shared? I am anxious to see what you have developed. I am particularly interested to see if it will work with a mobile phone LTE system.
