Part number for SMA socket
One of the SMA socket nuts became loose (the case has never come off before and no modifications have been done to the unit) and the SMA socket ended up shearing off.
I’m not mad, it’s out of warranty anyway.
Does anyone have a part number for it? Soldering a new one into the board is an easy prospect.
Thanks. David
That’s a custom part. Please email me and I’ll see if I have one somewhere. It’s actually not that easy to solder, due to all of the copper in the board. But you are welcome to try.
Well, crap. I can’t find your email address but if mine is viewable on the forum I am reachable there.
An update. Syed thank you for sending me a replacement SMA socket. I soldered the connector to the board with the help of a very hot soldering iron and a big flat bit.
I tinned everything before hand and then applied heat and a little bit more solder. It’s all working now.
