New "function" suggestion
Background:
Normal phone compass can many times be very unstable, and show wrong. And Heading with “Normal GPS” is only valid as long as you are moving.
My suggestion:
Can it be possible for KrakenSdr to use one input on RSPi5 to connect a GPS/GNSS compass. This type of compass for example Furuno deliver either NMEA or NMEA2000. But best for KrakenSdr is normal NMEA0183. And the only thing KrakenSdr needs to listen to is the HDT (True heading from north).
Now days its very cheap also to buy a GPS(RTK) compass online.
We are using here on all our pilot ships FURUNO GPS/GNSS compass. And instead of a big heavy gyro, gps compass is good and give a steady heading.
To be able to connect a GPS compass makes it easier to use a mobile direction finder, even when standing still.
It’s possible but so far I haven’t found a proper library that can support external compasses. It seems that to support external compasses we would need to support each one individually which is not feasible.
I believe there are some compass devices already supported by GPSD which is the library software we use for external GPS devices on the Pi. But so far I haven’t been able to determine exactly what compass devices are compatible as there doesn’t seem to be a list that tells me what supported compass devices there are.
You don’t need to focus on specific GPS/GNSS compasses, instead focus on the NMEA 0183 protocol, This protocol is international and the same for all equipment.
For those who don’t know what it is there is information here.
And there is only one NMEA that is interesting, and that is the heading.
I was actually on one pilot ship yesterday and working on a GPS/GNSS compass, and needed to remove a lot of NMEA that the track pilot didn’t need.
So krakenSdr only need to listen, and sort out the heading, and scrap the rest that compass is sending. Standard is 4800,8,1.
Do you have a recommendation for a reasonably priced GPS(RTK) compass that we could use for testing?
Commercial like Furuno, simrad etc is only found on surplus market for a private person, but cheap New, can for example be found at below link, Same or almost same can also be found on for example Aliexpress.
As you can see, almost all equipment use NMEA 0183, and that is very common protocol.
And on Aliexpress for example this.
Thanks, and I assume these also provide a GPS position as well as the heading?
Yes they do, and its better then a mobile phone.
Happy new year!!
Any progress with GPS/GNSS compass? Just asking because i will soon buy.
Br
Patrik
Hi happy new year! Sorry no progress on that yet, but we will be looking into it this year.
Hi, any news? Would be great to have a proper working compass.
We have been working around this problem, and have now a working program making 5 different antenna offset, but i having a question about the position and heading. If we feed the settings.json with heading and position, will krakensdr accept this?. Are testing a solution with a ESP32 and two GNSS receivers, and some code that do the matematiks.
I’m needing this too.
I’m doing a lot of drive-park-listen-drive-repeat. If I could pull off the road in a straight line, the “Hold Heading When Stationary” function might work, but that is never the case, so I’m having to manually enter in the bearing I’m facing, and the Lat/Long coordinates.
We need “Dual-Antennae GPS Heading”. In search by request “Mastering True North: 5 Ways to Determine Your Absolute Heading”. In this article, see the section “3. Dual-Antennae GPS Heading”. There are kits on sale, but they are very expensive. At the moment I am trying to make it myself. I have very little free time, and it does not work out quickly. If it works out well, I will let you know.
One thing that always trips me up with new functions is making sure the initial orientation is actually spot on. Most of the built-in phone apps are bloated with ads now, but I found this clean web tool lately- Online Compass | TheToolApp . It’s great for a fast heading verification without having to mess with a heavy app.
