Maximum current draw Bias-T
What is the maximum current draw for the Bias-T? On one of my channels, the Bias-T has stopped working. The devices I use draw a max of 120 mA, is this too much? I usually only use two at any time.
I double checked with the circuit designer, 120mA should be no problem, the limit is 200mA per channel.
The bias tee power is direct from the 5V supply, so as long as your supply can handle the additional power requirements of your bias tee peripherals, it will be fine.
