Is it normal for it to take around 7 minutes before the Kraken is ready to track?
Bill
It shouldn’t take that long. What computer system are you using? Do you have a long USB cable?
No, 3’ cables. The Kraken Settings Server shows the unit takes a long time to sync showing several red areas for about 2 minutes till it connects and syncs properly. Maybe 6 minutes from boot up to working. Not using any computer, just the Pixel 9 and its hotspot.
Are you using a Pi 4 or Pi 5? Cooling or no cooling?
The Pi 4 can take a few minutes to sync. The pi 5 is usually done within under a minute.
If the Pi is overheating, then it will throttle down the CPU and could cause sync to be slow.
