KrakenSDR Power Output
Hello,
Is there a way to output received power of a signal?
I’m working on some complex signal identification maths, and it would massively help if I could have the received power of a signal.
Regards,
Piers
The log files show RSSI Power in dB on column 4; is this not what you need?
The log files show RSSI, but note that this is not calibrated RSSI. You can only use it relatively. The KrakenSDR does not have a calibrated power measurement feature.
