KrakenSDR Antenna Design is very important for VHF
This image is a professional engineering infographic for a VHF Direction Finding (DF) antenna system, designed to explain how to build a stable and accurate KrakenSDR-style array.
:large_blue_diamond: Overall Concept
The diagram explains how to build a stable VHF DF antenna array that avoids common problems like phase errors, coupling, and signal distortion.
The key idea is:
Good antenna design = stable direction finding (DF)
Not just good SDR software.
:satellite_antenna: 1. Problems with VHF Whip Antennas
The left section shows why simple whip antennas are unstable for DF:
  • Phase center shifts with frequency
  • Strong mutual coupling between antennas
  • Narrowband behavior (resonance issues)
  • Interaction with mast and ground
  • Common-mode current on coax cables
:backhand_index_pointing_right: Result:
  • Unstable bearing
  • Jittery direction readings
  • Inconsistent DF results
:satellite_antenna: 2. Recommended Antenna: Sleeve Dipole Array
The center shows the best DF design:
:check_mark: 4-element sleeve dipole array
  • Mounted on fiberglass (non-metal) arms
  • Balanced radiation pattern
  • Stable phase center
Key advantage:
  • Much lower mutual coupling
  • More accurate phase measurement
  • Better DF stability than whip antennas
:high_voltage: 3. Common-Mode Current Problem
This section shows a major hidden issue:
  • Without ferrite choke → coax cable acts like antenna :cross_mark:
  • With ferrite choke → clean signal path :check_mark:
:backhand_index_pointing_right: Solution:
Use ferrite chokes (multiple turns) on every feedline.
:triangular_ruler: 4. Array Geometry (Top View)
This shows antenna placement:
  • 4 antennas in a symmetric square or cross shape
  • Ideal spacing ≈ ½ wavelength (λ/2)
Example:
  • At 150 MHz → about 1 meter spacing
:backhand_index_pointing_right: Important:
  • Geometry must be perfectly symmetrical
  • Even small errors affect DF accuracy
:brick: 5. Material Selection
Good vs bad materials:
:check_mark: Recommended:
  • Fiberglass arms
  • Plastic or insulated mounts
  • Non-metal structure
:cross_mark: Avoid:
  • Aluminum arms
  • Metal frames near antennas
  • Conductive support structures
:gear: 6. System Setup Recommendations
Best practices:
  • Use identical antennas and cables
  • Add ferrite chokes everywhere
  • Keep geometry fixed and rigid
  • Do frequency-based calibration
  • Disable dynamic tuning during DF tests
  • Use controlled test transmitter
:compass: 7. Calibration Procedure
Steps for accuracy:
  • Use a known transmitter signal
  • Measure from multiple angles
  • Record phase and amplitude
  • Build calibration model per frequency
  • Recalibrate when setup changes
:bar_chart: 8. Antenna Type Comparison
Stability ranking:
  • Cheap whip → :cross_mark: worst
  • Quarter-wave whip → low stability
  • Sleeve dipole → good :check_mark:
  • Folded dipole → better :check_mark::check_mark:
  • Adcock array → best :check_mark::check_mark::check_mark:
:brain: Key Insight (Very Important)
The bottom message of the image:
In VHF DF systems, the biggest limitation is antenna physics, not SDR software.
:high_voltage: Final Summary
This design guide is basically saying:
  • VHF DF is not just electronics
  • It is electromagnetics + mechanical engineering
  • Stability comes from:
    • clean antenna design
    • controlled geometry
    • low coupling system
The text was written by ChatGPT and/or Gemini I recognize that anywhere. Where did the graphic come from
