Kraken to TAKserver
Hello, I try to push DOA data in the tak server.
I use krakenos to PI5 and a computer.
When I use the software kraken to TAK to send the data on the tak server, it doesn’t work.
However, I created, in the tak configuration the entry with the IP adress valid but there are nothing on the tak’s map.
Could you help me, I don’t understand what it’s wrong ?
Did you make an input on the TAK Server?
At the beginning thank you to the answer. Yes I created an input on the TAK Server in the configuration/inputs and data feeds but the system display one error message which told :
“ALERT! The following ports suppoert unsecure connections : [8087]. Unencrypted ports may be exploited allowing unauthorized access to the system and sensitive information. See section 4.4 use setup wizard to configure TAK Server in the TAK server configuration. Guide for how to secude the configuration.”
Did you set the geo coordinates for your kraken listening stations? You set station ID, can use kraken pro local data format, and static location source. Without coordinates, I don’t know where it would put it on your map.
