I’m having the same problem this week as last. I’m trying to track a fox, but the kraken shows no lobes, bearings, anything on the map. The radio appears to be running ok. (March pi image.). The icon for tracking shows green even if I’m not moving I never goes back to red. Help needed. Settings pics attached.
You seem to have no DoA algorithm selected somehow, hence no output. ‘DoA algorithm’ under ‘DoA Configuration’ should be set to ‘MUSIC’
Also there appears to be no signal on your spectrum and nothing within the VFO bar.
If you’re testing while not moving, remember to set the app to ‘log everything’ temporarily, then back to pause at low speed when you’re in a vehicle.
