Kraken mobile app working logic
In the mobile app,what is the final grid value/ threshold after activations for which u decide the final location of Tx and what is default value of no.of grids per axis used in mobile app
Thanks!
Do you mean the threshold at which the circle turns from red to green? This is just an arbitrary value. It’s only purpose is to hold off on switching from a bearing average based distance, to the circle grid point for turn by turn navigation. Because initially the grid circle could be way off. But after a few minutes of data it should be at least pointing in the correct direction.
Green does not mean that the TX has been found, just that it’s now using that point for navigation.
