Just plug in your KerberosSDR (ensuring it is powered from the power port), and run the script ./eeprom_init.sh
. The script will guide you to use the DIP switches to turn all units off, except the currently requested tuner. It will then flash the realtek_oem firmware, then the serial number, before asking you to turn off that tuner, and turn on the next one. Answer Y
each time it asks to flash.
For me it does not work. Why?
Am I forgetting something?
You still need to enter the folder ~/krakensdr_doa/heimdall_daq_fw/util
first which is where the script is stored.
There is a script in
~/krakensdr_doa/heimdall_daq_fw/util/eeprom_init.sh
that can guide your through this. Just plug in your KerberosSDR (ensuring it is powered from the power port), and run the script./eeprom_init.sh
. The script will guide you to use the DIP switches to turn all units off, except the currently requested tuner. It will then flash the realtek_oem firmware, then the serial number, before asking you to turn off that tuner, and turn on the next one. AnswerY
