Kerberos SDR activate noise source in python
I do have a KerberosSDR that I would like to use with python (using PyRTLSDR). How can I turn on/off the noise source in Python? Could someone help me with the requited code to write the on/off byte?
Many thanks!
Best regards,
DC0NG
The noise source is controlled by GPIO 0 on the first RTL-SDR. To keep things simple you can just flip GPIO 0 on all tuners, as the other GPIO’s are unused.
In pyrtlsdr you can flip GPIO 0 using the set_bias_tee command. e.g. sdr.set_bias_tee(true)
@krakenrf_carl: Many thanks for your help! I could identify the noise source on GPIO 0 of tuner number 4. Very kind of you! Best, DC0NG
