I’m also trying to do the following on my windows PC through WSL. In summary I have cloned the heimdall_daq_fr repo in WSL and built it. For some reason I just cannot get the IQ data to stream on the TCP server.
I have done the following on my WSL terminal:
Ensured WSL has access to the RTL devices.
update & pick packages used by the Kraken install scripts
sudo apt update && sudo apt -y upgrade
essential build and runtime deps
sudo apt install -y build-essential git cmake libusb-1.0-0-dev pkg-config
lsof libzmq3-dev clang python3-dev python3-venv python3-pip wget
usbip client helpers for WSL
sudo apt install -y linux-tools-virtual hwdata
create a usable usbip command (sometimes the path includes kernel version)
sudo update-alternatives --install /usr/local/bin/usbip usbip $(command -v /usr/lib/linux-tools/*/usbip | tail -n1) 20 || true
cd ~ mkdir -p ~/krakensdr && cd ~/krakensdr
cloned the following repos:
krakenrf/librtlsdr.git
krakenrf/heimdall_daq_fw.git
krakenrf/gr-krakensdr.git
cd ~/krakensdr/librtlsdr
copy udev rules (ensures device permissions)
sudo cp rtl-sdr.rules /etc/udev/rules.d/rtl-sdr.rules
mkdir -p build && cd build
cmake ../ -DINSTALL_UDEV_RULES=ON
make -j$(nproc)
sudo make install
sudo ldconfig
copy the static librtlsdr archive and headers into the Heimdall daq core folder
cd ~/krakensdr/heimdall_daq_fw/Firmware/_daq_core
copy the created static lib + headers (path depends on librtlsdr build)
cp ~/krakensdr/librtlsdr/build/src/librtlsdr.a .
cp ~/krakensdr/librtlsdr/include/rtl-sdr.h .
cp ~/krakensdr/librtlsdr/include/rtl-sdr_export.h .
build Heimdall’s DAQ core
make -j$(nproc)
nano ~/krakensdr/heimdall_daq_fw/Firmware/daq_chain_config.ini
[data_interface]
default might be shmem — change to eth so Heimdall writes IQ to a TCP socket
out_data_iface_type = eth
copy into your krakensdr root (where Heimdall lives)
cp ~/krakensdr/gr-krakensdr/heimdall_only_start.sh ~/krakensdr/
cd ~/krakensdr
chmod +x heimdall_only_start.sh
start (runs Heimdall in IQ server mode; check logs)
./heimdall_only_start.sh
confirm port 5000 is listening
ss -tuln | grep 5000
or
sudo lsof -i -P -n | grep 5000
I cannot see any info when running the following:
or
I do not believe the software is actually running which is why is see no status on the port.
Some useful info:
:~/krakensdr/heimdall_daq_fw/Firmware$ cd ~/krakensdr/heimdall_daq_fw/Firmware
./daq_start_sm.sh # runs the DAQ chain and IQ server (port 5000)
Desig FIR filter with the following parameters:
Decimation ratio: 1
Bandwidth: 1.00
Tap size: 1
Window function: hann
FIR filter ready
Transfer funcfion is exported to : logs/Decimator_filter_transfer.html
Coefficients are exported to: data_control/fir_coeffs.txt
Starting DAQ Subsystem
Output data interface: Shared memory
'_’
Have a coffee watch radar
I would appreciate any help on this issue thank you. My main goal is to get acces to the coherent IQ data to do some custom processing.
