Hotspot credentials and control
I’ve been trying to figure out how to change the hotspot credentials from KrakenAndroid/KrakenAndroid to my own name and password.
And how to turn off the Pi hotspot so it will only connect to your phone’s hotspot.
Happy to go into the Pi’s code to make changes as I’m assuming that’s where this would need to be done I just can’t find it.
Cheers,
Jessie
You can edit the wpa_supplicant.conf file to change the hotspot credentials. Just SSH in or connect a monitor:
sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
12. Appendix · krakenrf/krakensdr_docs Wiki · GitHub
If you want to change the credentials of the hotspot generated by the Pi 4 itself.
cd Autohotspot
sudo ./autohotspot-setup.sh
Select option 7 and follow the instructions.
