is there software for calculating the layout of antenna array…? and what if we do custom antenna for specific frequency…
Use google to find krakensdr Excel spreadsheet for calculate spacing. Dont know how to send it here.
Any succes with using Kraken SDR on CB frequencies ?
The circular array seems to become to large to mount on a vehicle.
A linear array could be an option…
How large is the area you need covered?
is there any drawback on linear array… i modified the dimensions on calculator. im planning it for 1/4 wave.
as long as how the kraken can receive
Do I assume correctly that the CBs are normal handheld radios? Rather than mounting an array on a vehicle, can you install two or more arrays on a building?
