Having issue running the gui on ubuntu 22.04
Remote Control is DISABLED
To enable Remote Control please install miniserve and jq.
Then change ‘en_remote_control’ setting in _share/settings.json file to ‘true’.
Finally, apply settings by restarting the software.
Starting KrakenSDR Direction Finder
Web Interface Running at 0.0.0.0:8080
Data Out Server Running at 0.0.0.0:8081
TAK Server NOT Installed
everytim o run the command this comes up. I’ve rebooted and reran the commands and I still run into this issue. Thank you all for your support.
Hi, none of those are actual errors, they’re just indicating that special niche features are not enabled.
What is not working on your system?
