GPS receiver & magnetic compass
Hello.
Which GPS receiver can be used with Raspberry USB or GPIO connection? I want to buy a receiver with a magnetic compass.
I understand the presence of an accurate magnetic compass in the GPS receiver is critically necessary? KRAKENSDR will accept packets from gpsd?
Any GPS receiver that’s compatible with gpsd should work, although we haven’t tested all of them so can’t be totally sure. I’ve not tested a GPS/magnetic compass hybrid device yet though, I was under the impression from it’s documentation that gpsd does not support such devices.
A magnetic compass is not necessary as you can get the heading from the GPS while moving. But if you intend on not moving and don’t want to manually input a heading, a compass could help.
A GPS receiver by itself can only give you heading when you’re actually moving, so if you need a stable direction while stationary, a magnetometer/compass is usually the way to go. Just keep in mind that nearby electronics, antennas, and metal parts can throw the compass off and may need calibration.
When I was testing heading accuracy, I found it useful to compare readings against a simple reference tool like 123compass.org to see whether the issue was the sensor or the setup. Might be worth a quick check if you’re experimenting with different GPS/compass combinations.
