Hi, I am quite new at SDR. As I want to use GNU to do data analysis for krakensdr, and I used the lastest image file from Releases · krakenrf/krakensdr_doa · GitHub to drive Raspberry Pi 4.
Since, it is now quite difficult to set a connection using 127.0.0.1 with connecting the WIFI of krakensdr created by PI 4, cause I only follow GNU Radio OOT Block Install Instructions in gr-krakensdr on Ubuntu 20.04.
Could you please give some advice of how to solve the ‘Ethernet Connection Failed’ problem on GNU, does it mean even I flashed the image file on PI4, I still need to follow all manual installation steps of heimdall_daq_fw and krakensdr_doa if I want do data analysis in GNU.?
If so, shall I still need raspberry PI4 for the WIFI connection or just connect kraken device directly to PC to run with GNU?
Thanks in advance.
