Getting IQ Stream from Heimdall in Python
I am currently trying to get the IQ stream from the Heimdall in Python on a Raspberry Pi for a custom application. I have installed the heimdall_daf_fw from source, installed gnuradio, and installed gr-krakensdr from source. I made a simple script to attempt to connect with the KrakenSDR that is as follows:
import traceback
from gnuradio import gr, krakensdr
try:
    source = krakensdr.krakensdr_source("127.0.0.1",5000,5001,5,1575.42,[30.0] * 5,True)
    print("KrakenSDR source initialized successfully")
except Exception:
    traceback.print_exc()
When I run this, however, I get the following error:
admin@hostname:~ $ python test.py
Sending control message
Successful
Control interface communication finished
Reconfiguration succesfully finished
Failed to put IQ Samples into the Queue
Exception:
What is causing this error, and how should I be going about getting the IQ data directly from the Heimdall? For reference, the KrakenSDR does work when using the Web UI and I am able to see the waterfall for all 5 channels.
