I am having problem with DF in Frequency hopping spread spectrum signal. Any configuration I need to change in KrakenSdr software? The transmitter is a 900Mhz FHSS. Frequency keeps on changing. For fixed frequency, KrakenSdr is working OK.
You’ll need to set up multiple monitoring channels for all the frequencies the signal hops to. But it is not possible to track hopping signals beyond the 2.4 MHz bandwidth of the KrakenSDR.
What is your power output on the transmitter?
1watt.
How far from the transmitter is the KrakenSDR?
10 meters.
Are you testing this indoors or outdoors?
Indoors.
What about an unknown frequency transmitter with frequency hopping like rouge drones. How can we find it’s direction using Kraken DF?
If it just transmits on one channel at a time, within the 2.4 MHz bandwidth, then you can turn on “VFO-0 Auto Max” under VFO Mode. At then it will auto select the strongest signal in the spectrum. Of course if there are other signals that you do not want it will be a problem.
Just to clarify your final setup: did you end up doing DF by keeping KrakenSDR at a fixed center frequency (one channel) and capturing only the FHSS hops that happen to fall inside the ~2–2.4 MHz instantaneous bandwidth, then running DOA/DF on those captured bursts? Thanks a lot
