Exception: Failed to put IQ Samples into the Queue
Hello,
I’m having some trouble with heimdall and gnu radio, one of three scenarios happens:
  1. Throws Exception: Failed to put IQ Samples into the Queue immediately and repeatedly after running the flowchart.
  2. Throws Exception: Failed to put IQ Samples into the Queue after a random amount of time and never recovers, exceptions repeatedly until I terminate the file.
  3. It just works, but performance degrades over time, the DOA graph updates slower and slower.
I change nothing between reruns and the scenario changes. I’m guessing it has got something to do with queue overflowing? I tired turning down the sampling frequency but I’m not sure what that controls.
Any ideas of where I could look would be great!
Cheers,
Michael
What sort of system are you running on? Sounds like the computer isn’t able to keep up as the buffers get full.
Hello, I am having this error as well, I was wondering if you might have a recommendation for a fix for this. I am attempting to capture data on the kraken and then re-transmit through another SDR. Thank you.
If your computer is too slow to read from the buffers, then this error will happen. The only fix is to use a faster machine.
