I have an Orange Pi 4 LTS (Orange Pi 4 LTS - orange pi 4 lts) and want to use it with KrakenSDR.
Everything was installed well through the installation script krakensdr_aarch64_install_doa.sh. I can get into the web interface. But after running kraken_doa_start.sh in dmesg I see errors in dmesg: [ 3305.712876] usb 2-1-port2: disabled by hub (EMI?), re-enabling…
And status in web application is red.
Full output from dmesg:
[ 3305.712876] usb 2-1-port2: disabled by hub (EMI?), re-enabling...
[ 3305.715014] usb 2-1.2: USB disconnect, device number 9
[ 3305.950728] usb 2-1.2: new full-speed USB device number 14 using ohci-platform
[ 3306.071884] usb 2-1.2: not running at top speed; connect to a high speed hub
[ 3306.089853] usb 2-1.2: New USB device found, idVendor=0bda, idProduct=2838, bcdDevice= 1.00
[ 3306.089879] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3306.089886] usb 2-1.2: Product: RTL2838UHIDIR
[ 3306.089892] usb 2-1.2: Manufacturer: Realtek
[ 3306.089898] usb 2-1.2: SerialNumber: 1003
[ 3306.105833] usb 2-1-port3: disabled by hub (EMI?), re-enabling...
[ 3306.107855] usb 2-1.3: USB disconnect, device number 10
[ 3306.330752] usb 2-1.3: new full-speed USB device number 15 using ohci-platform
[ 3306.447858] usb 2-1.3: not running at top speed; connect to a high speed hub
[ 3306.465877] usb 2-1.3: New USB device found, idVendor=0bda, idProduct=2838, bcdDevice= 1.00
[ 3306.465907] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3306.465915] usb 2-1.3: Product: RTL2838UHIDIR
[ 3306.465921] usb 2-1.3: Manufacturer: Realtek
[ 3306.465926] usb 2-1.3: SerialNumber: 1002
[ 3306.481883] usb 2-1-port4: disabled by hub (EMI?), re-enabling...
[ 3306.483890] usb 2-1.4: USB disconnect, device number 11
[ 3306.710779] usb 2-1.4: new full-speed USB device number 16 using ohci-platform
[ 3306.827865] usb 2-1.4: not running at top speed; connect to a high speed hub
[ 3306.845852] usb 2-1.4: New USB device found, idVendor=0bda, idProduct=2838, bcdDevice= 1.00
[ 3306.845882] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3306.845889] usb 2-1.4: Product: RTL2838UHIDIR
[ 3306.845895] usb 2-1.4: Manufacturer: Realtek
[ 3306.845901] usb 2-1.4: SerialNumber: 1001
[ 3306.861940] usb 2-1-port5: disabled by hub (EMI?), re-enabling...
[ 3306.863899] usb 2-1.5: USB disconnect, device number 12
[ 3307.094795] usb 2-1.5: new full-speed USB device number 17 using ohci-platform
[ 3307.215872] usb 2-1.5: not running at top speed; connect to a high speed hub
[ 3307.233869] usb 2-1.5: New USB device found, idVendor=0bda, idProduct=2838, bcdDevice= 1.00
[ 3307.233896] usb 2-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3307.233903] usb 2-1.5: Product: RTL2838UHIDIR
[ 3307.233909] usb 2-1.5: Manufacturer: Realtek
[ 3307.233914] usb 2-1.5: SerialNumber: 1000
[ 3307.249900] usb 2-1-port6: disabled by hub (EMI?), re-enabling...
[ 3307.251905] usb 2-1.6: USB disconnect, device number 13
[ 3307.478826] usb 2-1.6: new full-speed USB device number 18 using ohci-platform
[ 3307.599877] usb 2-1.6: not running at top speed; connect to a high speed hub
[ 3307.617879] usb 2-1.6: New USB device found, idVendor=0bda, idProduct=2838, bcdDevice= 1.00
[ 3307.617906] usb 2-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3307.617913] usb 2-1.6: Product: RTL2838UHIDIR
[ 3307.617919] usb 2-1.6: Manufacturer: Realtek
[ 3307.617924] usb 2-1.6: SerialNumber: 1004
Kernel version:
# uname -a
Linux orangepi 5.15.80-rockchip64 #22.11.1 SMP PREEMPT Wed Nov 30 11:12:47 UTC 2022 aarch64 GNU/Linux
I checked the USB cables, everything works with a regular computer.
Question: how can I fix this problem?
Thank you!
