DOA screen compass graph type
I have small issue with DOA screen.
I set “DOA graph type” to compass type and expected to see direction to signal source, but intead I can see only one line which never change their position.
Can you please advice what I am doing worong?
Were you stationary or moving when you took that picture of your screen? If you were stationary, you need to set the Heading Sensor setting to manual, and then the Manual Mode Heading to the direction that ANT 0 in your array is pointed to.
Try refreshing the page. This happens when parts of the page don’t load correctly, but it’s quite rare.
Also you are in squelch at the moment as there is no signal in on the VFO frequency you have selected. The VFO is red as you can see in the spectrum image. So no data is being provided to the DOA algorithm, and hence it will not update.
