DOA Algorithm MUSIC & Decorrelation Toeplitzification
KrakenSDR with Pi5 and Oct2024-005 Version 1.8.1+git.e5df8c9 release up an running with DOA Algorithm MUSIC & Decorrelation Off.
If I change Decorrelation from Off to Toeplizification than Spectrum screen stops working. If I switch back to Decorrelation Off the Spectrum screen runs again as normal. Last time I tried to test these algotiths a few months ago with release V1.7.0 and Pi4 and Toeplizifikation with 3 RF stations the advise was to change from Pi4 to Pi5 (cpu power from Pi4 to weak). Are the functions Toeplizification, F-B Averaging, Spatial Smoothing, F-B Toeplitz with release Pi5 Oct24-005 Version 1.8.1+git.e5df8c9 out of scope? Please send advise.
Those options should be working, nothing has changed with them recently. It can take a few seconds for the numba JIT compiler to compile that code when you activate it for the first time though.
I note that these additional algorithms are just for research experimental purposes only. We do not recommend using them in normal DoA operations.
Yes, after I waited one or two minutes for initialization the DoA algorithm Toeplitzification runs perfect. And yes, I only use it for research. I am testing bearing against three New Packet Radio (NPR) transmitters sending on the same frequency in burst mode. Thanks for your advice.
