Hi all, I’m planning a project to detect and geolocate signals in the L-band (roughly 1100 to 1600 MHz) using a KrakenSDR mounted on a mid-sized fixed-wing UAV.
I’m currently looking at the SPK-6E Helical Triband Antenna, weight and aerodynamics are a big concern for this airframe.
Is there any fundamental reason why these antennas wouldn’t work well for direction finding in this band?
Has anyone done something similar on a UAV and can share suggestions for antennas that worked for them (or models to avoid)?
Also, to clarify on the hardware setup: Other options I am considering are active antennas, to use them correctly, do I just need to enable the Bias-T power for each channel in the software, or is there anything else I’m missing?
One concern with a UAV is that Kraken expects the platform to move in the direction of antenna 0 on the array. So it expects it to move more like a vehicle or airplane, which is contrained to move forwards only. So you’ll need to fly the UAV in the forward orientation always to get proper data.
Active antennas could work - you’d just need to activate the bias tee (assuming the ative circuitry is deisnged for 3-5V input), but they have a higher chance of introducing phase errors, which could be a big deal in the L-band.
Great, thank you for the info. The UAV I refer to is a fixed wing VTOL, so I can mostly ensure that antenna 0 is at the ‘front‘.
As for the antennae, I’ll likely buy a set of passive too and compare bearing results. I’m now more concerned about what the effect of the UAV banking will have as I have no easy way to gimbal the antenna rig…
The UAV I am using is very detuned so the bank maneuvers will be very gentle, but they will always occur at the end of each ‘mapping run‘ or in high wind, thoughts on the effect it will have? I could consider pausing the data collection while it is in a bank past x degrees.
I suppose the ideal would be to gimbal the antenna rig, or to be able to feed in attitude information, but that could get complicated for the calculations I imagine.
