Different processes in Kraken sdr DoA software
Hello, I would like to ask how many processes are used by the kraken sdr doa
software? Is everything (UI, DSP, block acquisition) running is the same process? As I can understand (from the update rate) the DSP is running in a different process than the block acquisition (thus if the update_rate is smaller than the block size we have not block loss). Where this happens in the code? Also, I can see that there is a pool that is used for writing async the output of DoA to the software needed.
Everything runs in it’s own process. Heimdall itself runs multiple producer consumer processes, which you can see startup here heimdall_daq_fw/Firmware/daq_start_sm.sh at main · krakenrf/heimdall_daq_fw · GitHub
The DOA DSP code is run in it’s own process too.
