DF on a noisy frequency
I plan to do some DF of a jammer on our local repeater. My question is how the Kraken deals with multiple signals - our jammer friend likes to key-up over other repeater users so there will often be two signals on the frequency. I will be closer to the jammer so his signal will be stronger, but how does the DF work with more than one signal?
You could try to adjust the a squelch level so that the Kraken only listens to the stronger (closer) station. The spectrum graph could help you tweak that.
It will mostly lock onto the strong signal, but the weaker signal could corrupt the results a bit. Definitely try using squelch to see if you can only activate the DFing when the jammer keys up.
