I have a Dell Wyse 5070 with Ubuntu 22.04 I’m looking to set up for use with the Kraken. I’m confused reading through the documentation and was wondering if anyone would be able to help me through the process.
Beginning questions:
Do I still need to run a VM?
Do I just need to run the install scripts? Do I need Docker, the x86 64 Bit Systems script, or both from the Install scripts page? (here)
I ordered an Android tablet but it won’t be here for a week. Am I able to access the web GUI directly through the Wyse in the meantime?
I got a refurb’d 1-liter PC and installed Ubuntu 22.04. I tried to install the software by [blindly] following the scripts, but couldn’t get things running. On my ToDo list is to go back and try again, with a bit more intention.
I’m under the impression that you should be able to fire it up and access the configuration web page from the PC from any device with a web browser that can see the PC on your network. The Android phone/tablet is only required to run the mapping program, which is an Android app. OTOH, the configuration pages are just a regular-ol’ web page.
I run the config page in a browser alongside an SDR app on a laptop and the mapping app on an Android device. This way, I can find and monitor stations on the laptop from a separate SDR receiver, program the frequency of interest in the Kraken via the browser, and then see the signals on the Android device. (I don’t do all this while driving, however )
It’s up to you if you want to use the install scripts or not, but I would recommend trying first with them as that is probably the easiest way to install them.
The install scripts install the software natively. Alternatively you can use the third party Docker solution but that is a third party installer not controlled by us directly.
I would recommend using a GUI-less install on the Wyse to save resources. These generally come with preciously little hard drive space and an OS with GUI is probably going to use up almost the entire HDD by itself.
But any other networked device, like a PC or phone (even an iPhone) will be able to access the web GUI. An Android device is only required to run the mapping software.
