Daq_chain_config.ini sample_rate=500k but receiving ~2.4MHz - Config not applied?
Hi KrakenSDR community,
I’ve searched the forum and found similar issues with low sample rates (like the 250kHz calibration problem), but my situation seems different.
My Setup:
  • KrakenSDR with latest Heimdall DAQ firmware
  • Raspberry Pi 4
  • GNU Radio on Ubuntu VM receiving via TCP port 5050
Issue:
Despite setting sample_rate = 500000 in daq_chain_config.ini, I’m consistently receiving ~2.0-2.4MHz worth of data in GNU Radio.
My config:
ini
[daq]
decimation_ratio = 1
center_freq = 147000000
[data_interface]
out_data_iface_type = eth
What I’ve verified:
  • Config file is being read (center_freq changes work)
  • Heimdall starts without errors
  • No GNU Radio decimation/interpolation blocks
  • Measured actual sample rate in Python embedded block
Specific questions:
  1. Does RTL-SDR hardware have minimum sample rate limitations that override config?
  2. Should I expect decimation to happen at DAQ level vs DSP level (as mentioned in the 250kHz thread)?
  3. Which log files should I check to see what sample rate RTL-DAQ actually sets?
I suspect the config isn’t being applied at the hardware level, but would appreciate guidance on debugging this.
Thanks!
Hm it should work at the lower sample rate, but if it’s not you could also try increasing the DAQ side decimation.
2.4 / 5 should get you to 480 kHz which would be near equivalent to setting the sample rate to 500 kHz.
